[geos-devel] [GEOS] #1043: [OverlayNG] tests/general/TestOverlayLL.xml fails
GEOS geos-trac at osgeo.org
Mon Aug 17 12:59:26 PDT 2020
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 OverlayGraph::addEdge is called only once, in GEOS, while it's called 3
 times in JTS. The missing 2 times are for both directions of the
 linearring edge
Ticket URL: <https://trac.osgeo.org/geos/ticket/1043#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
