[geos-devel] [GEOS] #1043: [OverlayNG] tests/general/TestOverlayLL.xml fails
geos-trac at osgeo.org
Mon Aug 17 13:02:44 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
Found the culprit: EdgeNodingBuilder::add, in GEOS, uses getGeometryTypeID
to decide what to do, and decides to do NOTHING for LineaRing. Instead JTS
uses an instanceOf operator (like a dynamic cast) which would see
LinearRing as being an instance of a LINESTRING
Ticket URL: <https://trac.osgeo.org/geos/ticket/1043#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
