[geos-devel] [GEOS] #1043: [OverlayNG] tests/general/TestOverlayLL.xml fails
geos-trac at osgeo.org
Mon Aug 17 13:11:05 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"e6ffc18a8de531f487088e7275a0af9d1d6736bc/git" e6ffc18/git]:
#!CommitTicketReference repository="git"
revision="e6ffc18a8de531f487088e7275a0af9d1d6736bc"
[OverlayNG] Fix handling of LinearRing
Closes #1043
Ticket URL: <https://trac.osgeo.org/geos/ticket/1043#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
