[geos-devel] [GEOS] #1034: Union topology exceptions lead to complete loss of floating point precision
geos-trac at osgeo.org
Fri Aug 21 12:44:34 PDT 2020
Reporter: dannytoone | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.0
Component: Default | Version: 3.8.0
Severity: Significant | Resolution:
Keywords: |
Comment (by dannytoone):
@mdavis
I found your repo where you're developing OverlayNG and I'm currently
trying to build it and use it on some of the geometries I've worked with.
It is [https://github.com/dr-jts/jts/tree/overlay-sr], right? And the
OverlayNGSnapIfNeeded.union method?
I could help with geometries and stack traces for any exceptions
thrown...is there an easy way to serialize the data that throws the
exceptions? I'm fairly unfamiliar with JTS and java in general, so any
help would be appreciated.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1034#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
