[geos-devel] Do you mind a GEOS-3.6.4 release ?
Sandro Santilli strk at kbt.io
Fri Dec 11 02:34:13 PST 2020
Release 3.6.3 came out in August 2018. Since then we have these
fixes:
  Changes in 3.6.4
  - Bug fixes / improvements
    - Fix crash in GEOSUnaryUnion with empty LineString
      (#928, Sergey Fedoseev)
    - Fix incorrect error return values in GEOSLength and
      GEOSisValidDetail (#941, Dan Baston)
    - Envelope constructor use strtod (#875)
    - Polygon build failure in Overlay difference (#789 Paul Ramsey)
    - Invalid union result from valid polygon inputs (#838)
    - Static library does not contain C API (#878)
    - Prevent crash when querying empty STRtree (#730)
    - Overlay performance improvement (#986, Paul Ramsey)
    - Relate crash with empty components (#1085, Sandro Santilli)
Are you ok with me releasing 3.6.4 ?
--strk;
