[geos-devel] Do you mind a GEOS-3.6.4 release ?
Martin Davis mtnclimb at gmail.com
Fri Dec 11 03:01:11 PST 2020
+1
On Fri., Dec. 11, 2020, 2:34 a.m. Sandro Santilli, <strk at kbt.io> wrote:
> Release 3.6.3 came out in August 2018. Since then we have these
> fixes:
>   Changes in 3.6.4
>   - Bug fixes / improvements
>     - Fix crash in GEOSUnaryUnion with empty LineString
>       (#928, Sergey Fedoseev)
>     - Fix incorrect error return values in GEOSLength and
>       GEOSisValidDetail (#941, Dan Baston)
>     - Envelope constructor use strtod (#875)
>     - Polygon build failure in Overlay difference (#789 Paul Ramsey)
>     - Invalid union result from valid polygon inputs (#838)
>     - Static library does not contain C API (#878)
>     - Prevent crash when querying empty STRtree (#730)
>     - Overlay performance improvement (#986, Paul Ramsey)
>     - Relate crash with empty components (#1085, Sandro Santilli)
> Are you ok with me releasing 3.6.4 ?
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201211/8cd181b4/attachment.html>
