[geos-devel] [GEOS] #1013: MultiLineString::reverse should not change component order
geos-trac at osgeo.org
Wed Feb 5 10:43:41 PST 2020
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.7.3
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by Dan Baston <dbaston@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"c01c8c1c30091d655ba888790c2daeec1f33bae3/git" c01c8c1/git]:
#!CommitTicketReference repository="git"
revision="c01c8c1c30091d655ba888790c2daeec1f33bae3"
Retain component order in MultiLineString::reverse
Updated for consistency with the behavior of other geometry types (as
changed in https://github.com/locationtech/jts/pull/513)
Fixes #1013
Ticket URL: <https://trac.osgeo.org/geos/ticket/1013#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
