[geos-devel] [GEOS] #1013: MultiLineString::reverse should not change component order
GEOS geos-trac at osgeo.org
Wed Feb 5 10:57:38 PST 2020
 Reporter:  dbaston     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.7.3
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Dan Baston <dbaston@…>):
 In [changeset:"45b28eb41288e31c7d489ee765ae633034efee94/git" 45b28eb/git]:
 #!CommitTicketReference repository="git"
 revision="45b28eb41288e31c7d489ee765ae633034efee94"
 Retain component order in MultiLineString::reverse
 Updated for consistency with the behavior of other geometry types (as
 changed in https://github.com/locationtech/jts/pull/513)
 Fixes #1013
Ticket URL: <https://trac.osgeo.org/geos/ticket/1013#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
