[geos-devel] [GEOS] #1015: Update geos-config tool for consistency
Greg Troxel
gdt at lexort.com
Tue Feb 18 12:28:42 PST 2020
Mike Taves <mwtoews at gmail.com> writes:
> On Wed, 19 Feb 2020 at 03:11, Greg Troxel <gdt at lexort.com> wrote:
>> In searching for the POSIX printf spec, I found this post about escaping
>> spaces in a portable manner.
>> https://stackoverflow.com/questions/12162010/posix-sh-equivalent-for-bash-s-printf-q
>> The specs at opengroup.org seem hard to deal with today - not sure if
>> they changed - but I found this POSIX printf description:
>> https://www.unix.com/man-page/POSIX/1posix/printf/
> Thanks for the resources!
Thank you for listening (seriously). We are, amusingly enough, moving
to a point where there is an assumption of all linux, much like the old
days when it was assumed all was windows.
>> > Currently, other Bash scripts are present in tools/ci/ but these are
>> > not installed with GEOS.
>> ci tools are quite a different story than a requirement for regular
>> installs, although I see using bash there (vs /bin/sh) as a bug also.
> I'll consider going over these to see if they can be POSIX /bin/sh
Thanks - I don't think that's nearly as big a deal, but in my experience
dealing with packaging I have found that many uses of bash were not
actually necessary or very easy to avoid. One common issue is using ==
in test, when POSIX specifies (and Bourne shells always were) just =.
>> None of the BSDs have bash by default. When it is present, via ports,
>> pkgsrc, etc., it's not in /bin. On NetBSD, it's in /usr/pkg/bin/bash.
>> People use it for their login shell. I do too - I'm not a bash hater,
>> but object to it for programming use. It's enormous, and is one
>> particular implementation among many. I view it as personal choice to
>> use it for interactive use, and not appropriate for scripting.
>> The fact that /bin/bash does not exist on *BSD, and probably other
>> places, prompted my question about looking for it and substituting the
>> path. Expecting bash to be in /bin/bash is just not a valid assumption.
>> So, given that there seems to be a way to do this without introducing a
>> dependenchy on bash, I'd like to see this backed out.
> Aha, so there are some that will be alienated, which I agree is a bad
> situation, so I'll submit a PR to restore back to #!/bin/sh
Great, thanks.
> I'll remove printf %q altogether and simply insert an escaped path to
> the script. I'll probably only do this with CMake, since that's the
> only install solution that supports spaces.
I didn't realize autoconf flat-out objected to spaces, but it is not
surprising since in the old-school command line tradition spaces is
files are somewhere between bizarre and unthinkable.
Sounds good to just escape spaces for cmake.
