[geos-devel] [GEOS] #1015: Update geos-config tool for consistency
Sandro Santilli strk at kbt.io
Tue Feb 18 23:23:51 PST 2020
On Tue, Feb 18, 2020 at 10:16:38PM +1300, Mike Taves wrote:
> On Tue, 18 Feb 2020 at 20:22, Sandro Santilli <strk at kbt.io> wrote:
> > > properly escape a path. While I see there is also /usr/bin/printf I'm
> > > not sure how common or standard this tool is (my tests with /bin/sh
> > > didn't go well, so I opted to switch to Bash for reliability).
> > GNU coreutils "printf" works fine here:
> >   [strk at liz:~] /usr/bin/printf "%q\n" "space 'quote' and \"doublequote\""
> >   'space '\''quote'\'' and "doublequote"'
> >   [strk at liz:~] /usr/bin/printf  --version | head -1
> >   printf (GNU coreutils) 8.28
> The printf function in Bash has supported the %q directive for much longer
> https://stackoverflow.com/a/26069697
> https://web.archive.org/web/20031119043100/http://www.gnu.org/software/bash/manual/bashref.html
> whereas the %q directive for /usr/bin/printf was introduced a few
> years ago, and seems to produce a different output, for example having
> a single quotation mark on either end of the above example. Bash's
> printf does not add single quotation marks to the output, as it is in
> a format that can be reused as shell input.
Do you have a use case for avoiding the single quotation mark from the
output of geos-config ?
Few-years-ago dependency could be fine, given GEOS requires C++10 now,
or we could just use quotes and allow for spaces in path names (while
still forbidding quotes and dollars etc. ?)
Do you have examples of paths you need to support ?
--strk;
