[geos-devel] OverlayNG for Testing
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jul 29 13:51:05 PDT 2020
Yes, I expect lots of internal failures, in addition to failures in external programs.
I'm looking at the unit test failures right now.
Some of them are representational, because the units tests don't bother to normalize before comparing geometries (since the overlay code consistently gave the same results).
Some of them are true behaviour changes. Hopefully many will be easily fixable.
Some of them will end up being deep conundrums.
If all you're going to do us run regression tests and tell me they fail... I'm doing that anyways. Be more creative.
P
> On Jul 29, 2020, at 1:42 PM, Regina Obe <lr at pcorp.us> wrote:
> Are these expected to fail?
> 344: Files: 1
> 344: Tests: 143
> 344: Failed: 0
> 344: Succeeded: 143
> 344/344 Test #344: validate-TestRelatePP .................................... Passed 0.01 sec
> 92% tests passed, 28 tests failed out of 344
> Total Test time (real) = 12.45 sec
> The following tests FAILED:
> 46 - unit-capi-GEOSGeom_setPrecision (Failed)
> 52 - unit-capi-GEOSIntersection (Failed)
> 57 - unit-capi-GEOSMakeValid (Failed)
> 79 - unit-capi-GEOSUnaryUnion (Failed)
> 148 - unit-operation-geounion-CascadedPolygonUnion (Failed)
> 152 - unit-operation-linemerge-LineMerger (Failed)
> 154 - unit-operation-overlay-OverlayOpUnion (Failed)
> 200 - general-TestFunctionAA (Failed)
> 201 - general-TestFunctionAAPrec (Failed)
> 202 - general-TestFunctionLA (Failed)
> 203 - general-TestFunctionLAPrec (Failed)
> 204 - general-TestFunctionLL (Failed)
> 205 - general-TestFunctionLLPrec (Failed)
> 207 - general-TestFunctionPL (Failed)
> 234 - general-TestUnaryUnion (Failed)
> 246 - issue-issue-geos-350 (Failed)
> 248 - issue-issue-geos-358 (Failed)
> 249 - issue-issue-geos-360 (Failed)
> 254 - issue-issue-geos-459 (Failed)
> 255 - issue-issue-geos-488 (Failed)
> 256 - issue-issue-geos-527 (Failed)
> 259 - issue-issue-geos-586 (Failed)
> 260 - issue-issue-geos-599 (Failed)
> 262 - issue-issue-geos-615 (Failed)
> 264 - issue-issue-geos-837 (Failed)
> 265 - issue-issue-geos-838 (Failed)
> 288 - misc-split (Failed)
> 292 - robust-TestRobustOverlayFixed (Failed)
> Errors while running CTest
>> -----Original Message-----
>> From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf
>> Of Paul Ramsey
>> Sent: Wednesday, July 29, 2020 3:54 PM
>> To: GEOS Development List <geos-devel at lists.osgeo.org>
>> Subject: [geos-devel] OverlayNG for Testing
>> OK, as requested it is now possible to test OverlayNG using C clients.
>> https://github.com/libgeos/geos/commit/c6774a6a48b2
>> For autotools, use
>> --enable-overlayng
>> For cmake, add
>> -DDISABLE_OVERLAYNG=OFF
>> No guarantees, this is completely untested, except insofar as it all still
>> compiles in the default state (which is overlayng off).
>> The goal, of course, is to get to a point before release where the default
>> state can be overlayng on.
>> Some things we already know don't work:
>> - 3D! GEOS uniquely has supported adding in Z coordinates to introduced
>> coordinates, and that code hasn't been added to JTS (and thus overlayng).
>> How this will affect existing expectations for 3D output is unknown, but it's
>> sure to be broken in some way.
>> - Union on linestrings! OverlayNG extracts maximal length linestrings from
>> the unioned graph. Old overlay extracted minimal length linestrings. This
>> change is probably "for the best" but it's a change which might impact
>> existing logic.
>> ATB,
>> P
>> geos-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
