[geos-devel] OverlayNG for Testing
Regina Obe
lr at pcorp.us
Wed Jul 29 14:35:07 PDT 2020
That was just to make sure I'm on the same page. Don't worry I'll be very creative.
> -----Original Message-----
> From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf
> Of Paul Ramsey
> Sent: Wednesday, July 29, 2020 4:51 PM
> To: GEOS Development List <geos-devel at lists.osgeo.org>
> Subject: Re: [geos-devel] OverlayNG for Testing
> Yes, I expect lots of internal failures, in addition to failures in external
> programs.
> I'm looking at the unit test failures right now.
> Some of them are representational, because the units tests don't bother to
> normalize before comparing geometries (since the overlay code consistently
> gave the same results).
> Some of them are true behaviour changes. Hopefully many will be easily
> fixable.
> Some of them will end up being deep conundrums.
> If all you're going to do us run regression tests and tell me they fail... I'm
> doing that anyways. Be more creative.
> P
> > On Jul 29, 2020, at 1:42 PM, Regina Obe <lr at pcorp.us> wrote:
> > Are these expected to fail?
> > 344: Files: 1
> > 344: Tests: 143
> > 344: Failed: 0
> > 344: Succeeded: 143
> > 344/344 Test #344: validate-TestRelatePP ....................................
> Passed 0.01 sec
> > 92% tests passed, 28 tests failed out of 344
> > Total Test time (real) = 12.45 sec
> > The following tests FAILED:
> > 46 - unit-capi-GEOSGeom_setPrecision (Failed)
> > 52 - unit-capi-GEOSIntersection (Failed)
> > 57 - unit-capi-GEOSMakeValid (Failed)
> > 79 - unit-capi-GEOSUnaryUnion (Failed)
> > 148 - unit-operation-geounion-CascadedPolygonUnion (Failed)
> > 152 - unit-operation-linemerge-LineMerger (Failed)
> > 154 - unit-operation-overlay-OverlayOpUnion (Failed)
> > 200 - general-TestFunctionAA (Failed)
> > 201 - general-TestFunctionAAPrec (Failed)
> > 202 - general-TestFunctionLA (Failed)
> > 203 - general-TestFunctionLAPrec (Failed)
> > 204 - general-TestFunctionLL (Failed)
> > 205 - general-TestFunctionLLPrec (Failed)
> > 207 - general-TestFunctionPL (Failed)
> > 234 - general-TestUnaryUnion (Failed)
> > 246 - issue-issue-geos-350 (Failed)
> > 248 - issue-issue-geos-358 (Failed)
> > 249 - issue-issue-geos-360 (Failed)
> > 254 - issue-issue-geos-459 (Failed)
> > 255 - issue-issue-geos-488 (Failed)
> > 256 - issue-issue-geos-527 (Failed)
> > 259 - issue-issue-geos-586 (Failed)
> > 260 - issue-issue-geos-599 (Failed)
> > 262 - issue-issue-geos-615 (Failed)
> > 264 - issue-issue-geos-837 (Failed)
> > 265 - issue-issue-geos-838 (Failed)
> > 288 - misc-split (Failed)
> > 292 - robust-TestRobustOverlayFixed (Failed) Errors while
> > running CTest
> >> Behalf Of Paul Ramsey
> >> Sent: Wednesday, July 29, 2020 3:54 PM
> >> Subject: [geos-devel] OverlayNG for Testing
> >> OK, as requested it is now possible to test OverlayNG using C clients.
> >> https://github.com/libgeos/geos/commit/c6774a6a48b2
> >> For autotools, use
> >> --enable-overlayng
> >> For cmake, add
> >> -DDISABLE_OVERLAYNG=OFF
> >> No guarantees, this is completely untested, except insofar as it all
> >> still compiles in the default state (which is overlayng off).
> >> The goal, of course, is to get to a point before release where the
> >> default state can be overlayng on.
> >> Some things we already know don't work:
> >> - 3D! GEOS uniquely has supported adding in Z coordinates to
> >> introduced coordinates, and that code hasn't been added to JTS (and thus
> overlayng).
> >> How this will affect existing expectations for 3D output is unknown,
> >> but it's sure to be broken in some way.
> >> - Union on linestrings! OverlayNG extracts maximal length linestrings
> >> from the unioned graph. Old overlay extracted minimal length
> >> linestrings. This change is probably "for the best" but it's a change
> >> which might impact existing logic.
> >> ATB,
> >> P
> >> _______________________________________________
> >> geos-devel mailing list
> >> https://lists.osgeo.org/mailman/listinfo/geos-devel
