[geos-devel] scan-build
Daniel Baston dbaston at gmail.com
Mon Mar 9 18:34:52 PDT 2020
Yeah, the reporting is pretty bad. If you search the log for "warning" you
will find the cause:
https://travis-ci.com/libgeos/geos/jobs/266448653#L1082
which is a false positive. The build shows as failed since it's from 3
months ago; Raul has since changed the configuration so that scan-build
reports but does not fail the build.
Dan
On Mon, Mar 9, 2020 at 6:20 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> I see “scan-build” has entered the CI zoo on master, and I see it has
> borked a PR, but I cannot see *why* it has borked it…
> Here’s the PR
> https://github.com/libgeos/geos/pull/252
> Here’s the build
> This is not actionable information, how is someone who has tripped this
> wire supposed to respond?
> P.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20200309/4ffe1624/attachment.html>
