[geos-devel] scan-build
rmrodriguez at carto.com rmrodriguez at carto.com
Tue Mar 10 01:33:50 PDT 2020
Yes, what Dan said is true.
After updating clang that false positive is gone and the build is
clean, but now a failure is accepted. Depending on useful it turns out
to be I might do some grep-foo to just throw the errors and summary in
the future.
On Tue, Mar 10, 2020 at 2:35 AM Daniel Baston <dbaston at gmail.com> wrote:
> Yeah, the reporting is pretty bad. If you search the log for "warning" you will find the cause:
> https://travis-ci.com/libgeos/geos/jobs/266448653#L1082
> which is a false positive. The build shows as failed since it's from 3 months ago; Raul has since changed the configuration so that scan-build reports but does not fail the build.
> Dan
> On Mon, Mar 9, 2020 at 6:20 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> I see “scan-build” has entered the CI zoo on master, and I see it has borked a PR, but I cannot see *why* it has borked it…
>> Here’s the PR
>> https://github.com/libgeos/geos/pull/252
>> Here’s the build
>> This is not actionable information, how is someone who has tripped this wire supposed to respond?
>> P.
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
Raúl Marín Rodríguez
carto.com
