[geos-devel] scan-build
Even Rouault even.rouault at spatialys.com
Tue Mar 10 04:37:12 PDT 2020
> Yes, what Dan said is true.
> After updating clang that false positive is gone and the build is
> clean, but now a failure is accepted. Depending on useful it turns out
> to be I might do some grep-foo to just throw the errors and summary in
> the future.
I faced a similar issue with GDAL.
The following might help to create a human friendly summary:
- in https://github.com/OSGeo/gdal/blob/master/gdal/ci/travis/csa_part_1/install.sh#L14
   ==> Using -o to output to a controled directory and -sarif for the json-based output format
- https://github.com/OSGeo/gdal/blob/master/gdal/ci/travis/csa_common/script.sh
   To postprocess all files written in the output directory and give first a detailed
   output, but not necessarily easy to understand. And a final summary section that contains
   just the filename, line and warning message.
   You may need to edit line 10 to remove a few GDAL specific exclusions of false
   positives (or things in external code we don't/wan't to control)
Even
http://www.spatialys.com
