[geos-devel] [GEOS] #544: Port JTS bugfix and testcases for MCIndexSnapRounder / GeometryNoder
GEOS geos-trac at osgeo.org
Mon May 4 15:14:10 PDT 2020
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.9.0
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by pramsey):
 Applying the change from JTS, which is a one-liner, breaks a test case
 from GEOS added earlier.
 https://sourceforge.net/p/jts-topo-
 suite/code/606/tree//trunk/jts/java/src/com/vividsolutions/jts/noding/snapround/MCIndexSnapRounder.java?diff=51a777ff34309d75519d9633:605
Ticket URL: <https://trac.osgeo.org/geos/ticket/544#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
