[geos-devel] [GEOS] #996: Windows CMake Mingw64 32-bit gcc 8.1.0
geos-trac at osgeo.org
Thu May 7 18:56:46 PDT 2020
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.8.2
Component: Default | Version: master
Severity: Significant | Resolution:
Keywords: |
Comment (by robe):
still failing
95% tests passed, 13 tests failed out of 266
Total Test time (real) = 34.97 sec
The following tests FAILED:
11 - unit-algorithm-LocatePointInRing (Failed)
14 - unit-algorithm-OrientationIndexFailure (Failed)
16 - unit-algorithm-RobustLineIntersection (Failed)
17 - unit-algorithm-RobustLineIntersector (Failed)
117 - unit-linearref-LengthIndexedLine (Failed)
118 - unit-math-DD (Failed)
130 - unit-operation-distance-DistanceOp (Failed)
165 - general-TestCentroid (Failed)
167 - general-TestConvexHull (Failed)
181 - general-TestInteriorPoint (Failed)
210 - issue-issue-geos-350 (Failed)
219 - issue-issue-geos-488 (Failed)
228 - issue-issue-geos-837 (Failed)
Errors while running CTest
So annoying that jenkins shows success
https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/DISABLE_GEOS_INLINE=OFF,GCC_TYPE=gcc81,GEOS_VER=$%7BGEOS_MINOR_VER%7D,MAKE_TYPE=cmake,OS_BUILD=32,PROJECTS=%2Fprojects/667/
Ticket URL: <https://trac.osgeo.org/geos/ticket/996#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
