[geos-devel] [GEOS] #859: Voronoi issue
    geos-trac at osgeo.org
    Tue Nov  3 16:11:20 PST 2020
#859: Voronoi issue
 Reporter:  jjgreen     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.6.4
Component:  Default     |     Version:  3.5.1
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 Replying to [comment:6 Paul Ramsey <pramsey@…>]:
 > Curiously, this case blows an exception on PostGIS, but not in the unit
 test.
 The reason the unit test passes is that the triangulation tolerance value
 (100) is larger than the extent of the input geometry.  This causes the
 data to collapse to a point, which produces an empty Voronoi diagram.  If
 a smaller tolerance (say 0.1) is used then the test fails with a Topo
 exception.
Ticket URL: <https://trac.osgeo.org/geos/ticket/859#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
