[geos-devel] OverlayNG as Default
Paul Ramsey pramsey at cleverelephant.ca
Wed Nov 11 17:33:32 PST 2020
It’s a big feature deal but I tend towards wanting to stick to semver...
not until we break backwards compatibility
On Wed, Nov 11, 2020 at 5:04 PM Daniel Baston <dbaston at gmail.com> wrote:
> This strikes me as a big deal - any thoughts on calling the next release
> GEOS 4?
> Dan
> On Tue, Nov 3, 2020 at 5:45 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> The switch has been flipped.
>> If you build GEOS without any options, you will get the OverlayNG engine
>> backing the standard geometry functions.
>> geom->union()
>> geom->intersection()
>> geom->symdifference()
>> geom->difference()
>> geom->unaryunion()
>> The unit and XML tests that differed from the old engine have been
>> updated to match the new NG outputs. That means if you use the
>> --disable-overlayng option in autotools or the DISABLE_OVERLAYNG option in
>> cmake, not all tests will pass anymore. NG is the new normal.
>> P.
>> On Fri, Oct 30, 2020 at 1:10 PM Regina Obe <lr at pcorp.us> wrote:
>>> +1 for flipping the switch.
>>> I don’t know what “light your hair on fair”   means J
>>> *From:* geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] *On
>>> Behalf Of *Paul Ramsey
>>> *Sent:* Friday, October 30, 2020 3:47 PM
>>> *To:* GEOS Development List <geos-devel at lists.osgeo.org>
>>> *Subject:* [geos-devel] OverlayNG as Default
>>> OK, it's been a while, and I'd like to flip over GEOS master to use
>>> OverlayNG as the engine behind
>>> Geometry.intersection()
>>> Geometry.difference()
>>> Geometry.union()
>>> Geometry.symdifference()
>>> Geometry.unaryunion()
>>> That will entail changing the expected outputs for a few of the
>>> regression tests, as detailed here.
>>> https://docs.google.com/document/d/1TDm2aR4a7O41-soS-25Xog1EdQcjmvKCnKltxjbxOC0/edit#heading=h.ojs23hjdmk7a
>>> Once that is done, regressions in PostGIS and other downstream projects
>>> can be #ifdef'ed around GEOS version. As seen in the document above, there
>>> actually aren't than many cases that need special handling in PostGIS, and
>>> hopefully not in other downstream projects.
>>> If you have any concerns, please light your hair on fair in the next
>>> couple days.
>>> P.
>>> geos-devel mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201111/cbed7ad3/attachment.html>
