[geos-devel] [GEOS] #1047: GEOS Panics on GeometryCollection with 1 MultiPolygon object
GEOS geos-trac at osgeo.org
Fri Nov 6 11:08:24 PST 2020
 Reporter:  otan        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.8.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"07e60468a9a155c63b06fa1e24db7c113f03004a/git" 07e6046/git]:
 #!CommitTicketReference repository="git"
 revision="07e60468a9a155c63b06fa1e24db7c113f03004a"
 Fix segfault in SimplePointInAreaLocator caused by casting MultiPolygon to
 Polygon
 Closes #1047
 References https://github.com/cockroachdb/cockroach/issues/53254
 Signed-off-by: Sandro Santilli <strk at kbt.io>
Ticket URL: <https://trac.osgeo.org/geos/ticket/1047#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
