[geos-devel] [GEOS] #976: Voronoi polygons robustness issue
GEOS geos-trac at osgeo.org
Fri Nov 6 12:34:22 PST 2020
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  reopened
 Priority:  major       |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"26cd4782faf7451c7a3df6a33a462b2669ef5153/git" 26cd478/git]:
 #!CommitTicketReference repository="git"
 revision="26cd4782faf7451c7a3df6a33a462b2669ef5153"
 Remove incorrect isoceles heuristic in
 QuadEdgeSubdivision::TriangleCircumcentreVisitor, fix unit test
 References #976 in master (3.9.0dev)
Ticket URL: <https://trac.osgeo.org/geos/ticket/976#comment:25>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
