[geos-devel] [GEOS] #976: Voronoi polygons robustness issue
GEOS geos-trac at osgeo.org
Fri Nov 6 12:37:00 PST 2020
 Reporter:  komzpa      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"e4a0126ab5b3eabafb8d805544a3f3af299acfbe/git" e4a0126/git]:
 #!CommitTicketReference repository="git"
 revision="e4a0126ab5b3eabafb8d805544a3f3af299acfbe"
 Remove incorrect isoceles heuristic in
 QuadEdgeSubdivision::TriangleCircumcentreVisitor
 Fix related unit test
 Closes #976 in 3.8 branch (3.8.2dev)
 The heuristic was added with 56417ce55
Ticket URL: <https://trac.osgeo.org/geos/ticket/976#comment:26>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
