[geos-devel] [GEOS] #1064: Topology preserve simplify: unexpected behavior on similar polygons
geos-trac at osgeo.org
Thu Nov 26 06:34:56 PST 2020
Reporter: uclaros | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Changes (by strk):
* cc: mbdavis (added)
Comment:
I guess one option here would be to pick the leftmost-upmost and the
rightmost-bottommost points of a ring, split the ring in two parts, merge
the lines which remain split by the origina vertex, then perform the
simplification on the two parts and join them back togheter.
What do you think Martin ?
Ticket URL: <https://trac.osgeo.org/geos/ticket/1064#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
