[geos-devel] [GEOS] #1054: BuildArea behavior changed intentional? and when did it happen
geos-trac at osgeo.org
Mon Oct 5 13:52:26 PDT 2020
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Keywords:
strk suggested I put the ticket
https://trac.osgeo.org/postgis/ticket/4763
Here as PostGIS uses GEOS directly for ST_BuildArea.
The issue is:
SELECT ST_BuildArea('MULTIPOLYGON(((186.464466094067
193.535533905933,187.222148834902 194.157348061513,188.086582838175
194.619397662556,189.024548389919 194.903926402016,190
195,190.975451610081 194.903926402016,191.913417161825
194.619397662556,192.777851165098 194.157348061513,193.535533905933
193.535533905933,194.157348061513 192.777851165098,194.619397662556
191.913417161825,194.903926402016 190.975451610081,195
190,194.903926402016 189.024548389919,194.619397662556
188.086582838175,194.157348061513 187.222148834902,193.535533905933
186.464466094067,13.5355339059327 6.46446609406726,12.777851165098
5.84265193848727,11.9134171618254 5.38060233744356,10.9754516100806
5.09607359798385,10 5,9.02454838991936 5.09607359798385,8.08658283817455
5.38060233744357,7.22214883490199 5.84265193848727,6.46446609406726
6.46446609406726,5.84265193848728 7.22214883490199,5.38060233744357
8.08658283817455,5.09607359798385 9.02454838991935,5
9.99999999999999,5.09607359798385 10.9754516100806,5.38060233744356
11.9134171618254,5.84265193848727 12.777851165098,6.46446609406726
13.5355339059327,186.464466094067 193.535533905933)),((150
90,149.039264020162 80.2454838991936,146.193976625564
70.8658283817455,141.573480615127 62.2214883490199,135.355339059327
54.6446609406727,127.77851165098 48.4265193848728,119.134171618255
43.8060233744357,109.754516100806 40.9607359798385,100 40,90.2454838991937
40.9607359798385,80.8658283817456 43.8060233744356,72.22148834902
48.4265193848727,64.6446609406727 54.6446609406725,58.4265193848728
62.2214883490198,53.8060233744357 70.8658283817454,50.9607359798385
80.2454838991934,50 89.9999999999998,50.9607359798384
99.7545161008062,53.8060233744356 109.134171618254,58.4265193848726
117.77851165098,64.6446609406725 125.355339059327,72.2214883490197
131.573480615127,80.8658283817453 136.193976625564,90.2454838991934
139.039264020161,99.9999999999998 140,109.754516100806
139.039264020162,119.134171618254 136.193976625564,127.77851165098
131.573480615127,135.355339059327 125.355339059327,141.573480615127
117.77851165098,146.193976625564 109.134171618255,149.039264020162
99.7545161008065,150 90)))'::geometry);
Used to look like:
[[Image(before_gaping_hole.png)]]
But now looks like
[[Image(after_gaping_hole_no_more.png)]]
SELECT ST_BuildArea('MULTIPOLYGON(((91 50,79 22,51 10,23 22,11 50,23 78,51
90,79 78,91 50)),((91 100,79 72,51 60,23 72,11 100,23 128,51 140,79 128,91
100)),((91 150,79 122,51 110,23 122,11 150,23 178,51 190,79 178,91
150)),((141 50,129 22,101 10,73 22,61 50,73 78,101 90,129 78,141
50)),((141 100,129 72,101 60,73 72,61 100,73 128,101 140,129 128,141
100)),((141 150,129 122,101 110,73 122,61 150,73 178,101 190,129 178,141
150)))'::geometry);
Used to Look like:
[[Image[before_beautiful_beehive.png]]
After
[[Image[after_boring_beehive.png]]
I think this has been (broken for me) and it's unclear if this was an
intentional change or not. I personally prefer the old behavior, but as I
review more I can understand how someone may have decided the new behavior
was more predictable and thus better.
So it's been like this I would say probably since 3.6 (maybe even as early
as 3.5). One pattern I see with the failures is they are all invalid
polygons. So perhaps it's doing an UnaryUnion or something before feeding
to ST_BuildArea.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1054>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
