[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Wed Oct 7 13:06:45 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Sandro Santilli <strk@…>):
In [changeset:"e2157728ed6c5a41155b8f9d69d79ab758d63ed4/git" e215772/git]:
#!CommitTicketReference repository="git"
revision="e2157728ed6c5a41155b8f9d69d79ab758d63ed4"
Port JTS fix for very close nodes on same segment.
References #1051 fixing its root cause.
This commit partially reverts abb96620c275 to avoid hiding
eventual other missing ports from JTS.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:31>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
