[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Wed Oct 7 13:08:14 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
Yes, and we now use that exception. I'm leaving this ticket open waiting
for your new fix test to land in JTS and port here (or please close the
ticket if you don't think you'll create such test)
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:32>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
