[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Mon Oct 12 07:28:44 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by strk):
* status: reopened => closed
* resolution: => fixed
Comment:
All tests ported, thanks !
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:36>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
