[geos-devel] Is Overlay-NG active?
Roger Bivand Roger.Bivand at nhh.no
Thu Oct 15 08:59:39 PDT 2020
Can I ask whether there is, or could be, a function exposed in the C_API,
or a header variable say in geoc_c.h, showing whether the running GEOS is
using Overlay-NG or not?
After help from the list, I've now run checks on R packages either
themselves linking to GEOS, or using functions from packages which do link
to GEOS. A half-dozen or so fail on unit tests, typically because the
ordering  of coordinates varies (say same polygon, but starting at  a
different place), or the ordering of sub-geometries (say slivers from a
Union operation) varies from before Overlay-NG. The objects are the same
(for given precision), but unit tests in packages compare the WKT of the
output geometry with the expected WKT (often generated from output before
Overlay-NG).
So if we could provide a way for the unit tests to compare correctly
branching on Overlay-NG or not, the package maintainers could avoid
having to scramble when platforms and R packages linking to GEOS begin to
appear.
Another question raised by package maintainers - do we know when 3.9.0 may
be expected, and will it have Overlay-NG? However, providing them with an
easy way to ask the GEOS runtime if it is Overlay-NG or not will relieve
the pressure.
Anyway, the failure count is very low, a half-dozen from hundreds is fine
(and if they didn't write tests, that isn't our problem...).
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
