[geos-devel] Checking GEOS master (state 8 October)
Martin Davis
mtnclimb at gmail.com
Tue Oct 13 12:06:27 PDT 2020
That output is coming from HeuristicOverlay.cpp:
https://github.com/libgeos/geos/blame/c4aebbbc048618e75b39f6c8d85dce8e8216cf9f/src/geom/HeuristicOverlay.cpp#L206
It shouldn't be showing up unless GEOS_DEBUG_HEURISTICOVERLAY has been
enabled, however.
On Tue, Oct 13, 2020 at 11:40 AM Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Tue, 13 Oct 2020, Paul Ramsey wrote:
> > In Cmake set DISABLE_OVERLAYNG to OFF
> Thanks, never Cmake here, am trying ../configure --enable-overlayng. I'm
> still puzzled about the free output to console not going through the error
> or warning handler.
> Roger
> > P
> >> On Oct 13, 2020, at 11:23 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> >>>> On Oct 13, 2020, at 11:08 AM, Roger Bivand <Roger.Bivand at nhh.no>
> wrote:
> >>>> I've been checking the possible fallout from Overlay_NG (assuming
> that building from master on 8 October uses the new code) in some R
> packages, in particular sf and rgeos. I see messages such as:
> >>>> CBR: result (after common-bits addition) is INVALID:
> Self-intersection at or near point 368576.69999999995 864696
> (368576.69999999995343 864696)
> >>> That looks like the old overlay handler. Have you turned NG on in your
> build?
> >> Thanks for the quick response. First, is "master" the correct branch
> (gitea)? If yes, what is the incantation - I couldn't find any reference to
> NG in the code or configure.ac? I'd assumed from earlier discussion here
> that NG was on by default on "master".
> >> Roger
> >>> P
> >>>> followed by the text representation of the object dumped to console.
> The message and the dumped object are not passed through error or warning
> handlers passed in through initGEOS_r(), and so are hard to trap and
> handle. Is this a temporary feature which will be normalised for 3.9.0?
> >>>> So far I don't think that there are obvious failures in R packages
> related to the new code (again assuming that a straight build of master of
> 8 November exercises Overlay_NG), but the unexpected output was surprising.
> >>>> Best wishes,
> >>>> Roger
> >>>> Roger Bivand
> >>>> Department of Economics, Norwegian School of Economics,
> >>>> Helleveien 30, N-5045 Bergen, Norway.
> >>>> voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
> >>>> https://orcid.org/0000-0003-2392-6140
> >>>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
> >>>> _______________________________________________
> >>>> geos-devel mailing list
> >>>> geos-devel at lists.osgeo.org
> >>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
> >> Roger Bivand
> Roger Bivand
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201013/f49ed831/attachment.html>
