[geos-devel] Unit testing Overlay operations
Martin Davis mtnclimb at gmail.com
Thu Oct 15 13:57:03 PDT 2020
As noted in a recent thread, it's tricky to create unit tests for overlay
operations. One reason for this is that the order of the result components
and coordinates is undefined, and so can vary between diifferent algorithms
and even different library releases.   (The lack of well-defined ordering
is deliberate, since introducing ordering would reduce performance).
The solution to this is to normalize the actual result (and possibly the
expected value, to ensure it is stable).  This imposes a well-defined
ordering.  It works well for cases which are hand-crafted to test overlay
functionality.
But overlay results can vary in other ways as well, due to the use of
different algorithms, different handling of numerical precision, and the
heuristics used to ensure robustness.  This is much harder to handle.  In
GEOS we deal with this in a limited way by testing area and length of the
result, rather than the actual result geometry.  This is obviously a fairly
weak test, and it's used mostly for checking robustness (which tends to
produce either grossly wrong results or outright failure).
A further option would be to use some kind of similarity metric.  JTS has
used Area of Symmetric Difference and Hausdorff distance to unit test the
buffer operation (which has this problem as well). I've also experimented
with a "pinhole" method, involving generating points within a given
distance of the input and result linework.
To keep things simple, it's easiest to use relatively simple geometry to
test functionality, and cruder comparisons to test robustness.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201015/2f631ee3/attachment-0001.html>
