[geos-devel] Testing OverlayNG robustness in R-sf
Martin Davis
mtnclimb at gmail.com
Fri Oct 16 12:55:05 PDT 2020
On Fri, Oct 16, 2020 at 11:59 AM Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Cases 794 and 936 are all-by-all intersections, and as noted in the latter
> issue, the problems occurring differ by input order.
Well, that's disappointing that 794 and 936 still have failures.
Especially because 794 was also reported as JTS 300:
https://github.com/locationtech/jts/issues/300
and the test data there is incoporated in the robustness test suilte in
both JTS [1] and GEOS [2] , where it passes using OverlayNG.
Is there any way to get a dump of the actual input geometries to GEOS which
are causing these errors?
[1]
https://github.com/locationtech/jts/blob/master/modules/tests/src/test/resources/testxml/robust/overlay/TestOverlay-jts-300.xml
[2]
https://git.osgeo.org/gitea/geos/geos/src/branch/master/tests/xmltester/tests/robust/overlay/TestOverlay-jts-300.xml
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201016/891f2ca6/attachment.html>
