[geos-devel] OverlayNG as Default
Regina Obe
lr at pcorp.us
Fri Oct 30 13:09:58 PDT 2020
+1 for flipping the switch.
I don’t know what “light your hair on fair” means :)
From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Friday, October 30, 2020 3:47 PM
To: GEOS Development List <geos-devel at lists.osgeo.org>
Subject: [geos-devel] OverlayNG as Default
OK, it's been a while, and I'd like to flip over GEOS master to use OverlayNG as the engine behind
Geometry.intersection()
Geometry.difference()
Geometry.union()
Geometry.symdifference()
Geometry.unaryunion()
That will entail changing the expected outputs for a few of the regression tests, as detailed here.
https://docs.google.com/document/d/1TDm2aR4a7O41-soS-25Xog1EdQcjmvKCnKltxjbxOC0/edit#heading=h.ojs23hjdmk7a
Once that is done, regressions in PostGIS and other downstream projects can be #ifdef'ed around GEOS version. As seen in the document above, there actually aren't than many cases that need special handling in PostGIS, and hopefully not in other downstream projects.
If you have any concerns, please light your hair on fair in the next couple days.
P.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20201030/14c8f86f/attachment.html>
