[geos-devel] [GEOS] #1035: VoronoiLines and VoronoiPolygons hangs indefinitely on multipoint
GEOS geos-trac at osgeo.org
Sat Oct 31 16:58:46 PDT 2020
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 See also #976 and #859.
 This case works fine in JTS.
 It seems that the fix that worked in JTS (computing triangle
 circumcentres) does not work in GEOS?
Ticket URL: <https://trac.osgeo.org/geos/ticket/1035#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
