[geos-devel] [GEOS] #1035: VoronoiLines and VoronoiPolygons hangs indefinitely on multipoint
geos-trac at osgeo.org
Sat Oct 31 21:32:46 PDT 2020
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
That's a pretty massive tolerance value compared to the scale of the
input. It's possible that has something to do with the infinite loop. If
so, still need to figure out a way to disallow it, at least.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1035#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
