[geos-devel] Complexity of algorithms
Martin Davis
mtnclimb at gmail.com
Thu Sep 3 09:37:59 PDT 2020
Hi. The algorithms in GEOS are almost all ported from the JTS Topology
Suite, fyi.
The reason for not having explicit documentation for algorithm complexity
is time/effort, and difficulty of proving the complexity.
In general the algorithms should be roughly O(n log n) (as opposed to the
O(n^2) that would result from a naive implementation, which is too slow for
production use). The complexity may also be data-dependent, since despite
best efforts there may be one or two O(n^2) steps in the code for certain
geometry cases.
On Thu, Sep 3, 2020 at 6:46 AM Zachary Déziel <Zachary.Deziel at usherbrooke.ca>
wrote:
> Hi all,
> Sorry for disturbing and I hope I am passing through the right channel for
> my question. If not, please feel free to redirect me!
> I have been searching in the documentation and elsewhere for information
> regarding the time complexity of the algorithms of GEOS. More precisely
> around the classic operations on point, line and polygon data structures
> (buffer, intersect, etc). The only mention of complexity I found was
> regarding a trade-off between simplicity for the intersection method. Is
> there some hidden documentation somewhere that covers the time and/or
> memory complexity of the algorithms? If no such documentation exists, are
> there reasons for it not existing? Is it simply a matter of not being a
> priority in the development cycle?
> Sorry for the compact and numerous questions, if you have any interest in
> the subject please reach out.
> Sincerely,
> Zachary Deziel
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20200903/1972b40d/attachment.html>
