[geos-devel] [GEOS] #960: Exception when creating geometry buffer
geos-trac at osgeo.org
Mon Sep 14 12:46:46 PDT 2020
Reporter: allenkim0129 | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone:
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: Buffer, TopologyException |
Comment (by mdavis):
Replying to [comment:3 strk]:
> Martin can the usability range be computed to avoid such occurrences ?
Maybe. It might be that if the length of the end segments is less than
the buffer distance then there may be visual artifacts present. That
would certainly include this case. It's an overly aggressive heuristic
though, since it would prevent running lots of cases which would not show
artifacts.
A more sophisticated heuristic would be to check if the end cap line
intersected any of the side offset lines.
But if what you are suggesting is throwing an error such as "Unable to
compute buffer for given buffer distance", then this could just be emitted
as the error when a TopologyException occurs.
Ticket URL: <https://trac.osgeo.org/geos/ticket/960#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
