[geos-devel] [GEOS] #960: Exception when creating geometry buffer
GEOS geos-trac at osgeo.org
Mon Sep 28 03:44:00 PDT 2020
 Reporter:  allenkim0129               |       Owner:  geos-devel@…
     Type:  defect                     |      Status:  closed
 Priority:  blocker                    |   Milestone:
Component:  Default                    |     Version:  3.6.2
 Severity:  Unassigned                 |  Resolution:  fixed
 Keywords:  Buffer, TopologyException  |
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"23ce93fe1ed062fca0ad035fca54e0002570b7f0/git" 23ce93f/git]:
 #!CommitTicketReference repository="git"
 revision="23ce93fe1ed062fca0ad035fca54e0002570b7f0"
 Add test for ticket #960
 No exception is thrown, so this commit
 closes #960
Ticket URL: <https://trac.osgeo.org/geos/ticket/960#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
