[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Mon Sep 28 08:27:33 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
A quick hack/fix would be to change the EdgeMerger assertion into a
TopologyException. Then the OverlayNGRobust logic I think would drop
through to use Snap-Rounding, which should work.
It would be nice to fix the noding code, however - if that's possible.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
