[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Mon Sep 28 12:25:46 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
Martin I'm unable to use the -geomfunc option, can you give full
commandline ?
I'm getting:
java.lang.ClassNotFoundException:
org.locationtech.jtstest.function.OverlayNGRobustFunctions
org.locationtech.jts.operation.overlayng.OverlayNGRobust
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
