[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
GEOS geos-trac at osgeo.org
Tue Sep 29 10:11:11 PDT 2020
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.9.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by mdavis):
 Hmm, I'm actually suprised to hear that, since I realized that
 `testrunner.sh` runs a jar file that doesn't include the `app` module
 classes.
 Here's a command line that works for me.  In the JTS root dir:
 java -cp modules/app/target/JTSTestBuilder.jar \
 org.locationtech.jtstest.testrunner.JTSTestRunnerCmd \
 -geomfunc org.locationtech.jtstest.function.OverlayNGRobustFunctions  \
 org.locationtech.jts.operation.overlayng.OverlayNGRobust \
 -files TestOverlayNG-geos-1051.xml
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
