[geos-devel] [GEOS] #1051: overlayng::EdgeMerger::merge(): Assertion `baseEdge->size() == edge->size()' failed.
geos-trac at osgeo.org
Tue Sep 29 11:31:44 PDT 2020
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by mdavis):
One way to try and bisect the cause of this problem is to choose some info
to dump out during noding, and compare to JTS. Could start with the
points that are snapped. Also the final set of edge before merging would
be interesting to compare (since that is apparently the source of the
error).
Ticket URL: <https://trac.osgeo.org/geos/ticket/1051#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
