[geos-devel] PR for new GeometryFixer API
Paul Ramsey
pramsey at cleverelephant.ca
Mon Apr 19 13:44:31 PDT 2021
Important question for downstream maintainers: how wedded are you to
current 'makevalid' output? If you have tests of 'makevalid' right now, and
we replaced the default behaviour with the GeometryFixer, you'd get
different looking (valid) results.
https://github.com/libgeos/geos/pull/433#issuecomment-821597724
However different looking, they are in many cases "more right" looking (in
some cases there's no obviously "right" answer, but in many there are ones
with more rightnesss). In general the processing in geometryfixer should be
faster too (fewer big overlay ops in total).
But still: different. All those unit tests.
What's your tradeoff?
P
On Fri, Apr 16, 2021 at 1:05 PM Martin Davis <mtnclimb at gmail.com> wrote:
> JTS recently had a class called GeometryFixer added. The class provides
> functionality to accept any invalid geometry and convert it to a valid
> one. This plugs a noticeable gap in the JTS API!
> Paul R has ported this to GEOS: https://github.com/libgeos/geos/pull/433
> It performs a similar function to the existing GEOS MakeValid (which was a
> port of the PostGIS ST_MakeValid). But it has some differences in
> semantics which are simpler and (hopefully) a useful alternative.
> See the PR for links to documentation of the functionality of
> GeometryFixer (and there will be more docs and images coming soon).
> Feedback is welcome, as always.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20210419/40100bcf/attachment.html>
