[geos-devel] PR for new GeometryFixer API
Even Rouault even.rouault at spatialys.com
Mon Apr 19 14:20:40 PDT 2021
Hi Paul,
no impact for GDAL test suite. It tests MakeValid() in a very light way
(using mostly the "hourglass" looking invalid polygon)
Even
Le 19/04/2021 à 22:44, Paul Ramsey a écrit :
> Important question for downstream maintainers: how wedded are you to
> current 'makevalid' output? If you have tests of 'makevalid' right
> now, and we replaced the default behaviour with the GeometryFixer,
> you'd get different looking (valid) results.
> https://github.com/libgeos/geos/pull/433#issuecomment-821597724
> <https://github.com/libgeos/geos/pull/433#issuecomment-821597724>
> However different looking, they are in many cases "more right" looking
> (in some cases there's no obviously "right" answer, but in many there
> are ones with more rightnesss). In general the processing in
> geometryfixer should be faster too (fewer big overlay ops in total).
> But still: different. All those unit tests.
> What's your tradeoff?
> P
> On Fri, Apr 16, 2021 at 1:05 PM Martin Davis <mtnclimb at gmail.com
> <mailto:mtnclimb at gmail.com>> wrote:
>     JTS recently had a class called GeometryFixer added.  The class
>     provides functionality to accept any invalid geometry and convert
>     it to a valid one.  This plugs a noticeable gap in the JTS API!
>     Paul R has ported this to GEOS:
>     <https://github.com/libgeos/geos/pull/433>
>     It performs a similar function to the existing GEOS MakeValid
>     (which was a port of the PostGIS ST_MakeValid). But it has some
>     differences in semantics which are simpler and (hopefully) a
>     useful alternative.
>     See the PR for links to documentation of the functionality of
>     GeometryFixer (and there will be more docs and images coming soon).
>     Feedback is welcome, as always.
>     _______________________________________________
>     geos-devel mailing list
>     geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/geos-devel
>     <https://lists.osgeo.org/mailman/listinfo/geos-devel>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20210419/4b6af222/attachment.html>
