[geos-devel] [GEOS] #1122: BuildArea is slow when there are many holes
GEOS geos-trac at osgeo.org
Thu Aug 12 08:37:36 PDT 2021
 Reporter:  strk         |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  3.9.2
Component:  Default      |     Version:  3.9.0
 Severity:  Unassigned   |  Resolution:
 Keywords:               |
Comment (by strk):
 I've ended up reimplementing it, could you check the merge request again
 please ?
 https://gitlab.com/geos/libgeos/-/merge_requests/3
Ticket URL: <https://trac.osgeo.org/geos/ticket/1122#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
