[geos-devel] RFC7: Discontinue use of autotools
Even Rouault even.rouault at spatialys.com
Fri Jan 8 15:41:45 PST 2021
> I'm pretty sure the majority of the above committers (also)
> use autotools, so the first motivation is not enough.
I'd be fine with a CMake-only build system.
https://travis-ci.org/github/uclouvain/openjpeg is an exemple of cmake used
with cross-compilation targets (mingw compiler with Linux host)
I know people build openjpeg in a buildroot context, so with cross compilers.
Even
http://www.spatialys.com
