[geos-devel] RFC7: Discontinue use of autotools
Daniel Baston dbaston at gmail.com
Sat Jan 9 17:44:15 PST 2021
> Make the CMake build adhere to CMAKE_INSTALL_LIBDIR so that multiarch
> keeps working,
I created a pull request for this at
https://github.com/libgeos/geos/pull/380
Have CMAKE_BUILD_TYPE=None define NDEBUG so that assert() is removed
> from the code, thereby not storing the buildpath in the binaries helping
> reproducible builds.
If you don't specify CMAKE_BUILD_TYPE it defaults to Release, and NDEBUG
will be defined. Do you mean that we should define a new build type called
"None" ?
Dan
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20210109/8d2fe203/attachment.html>
