[geos-devel] RFC7: Discontinue use of autotools
Sebastiaan Couwenberg sebastic at xs4all.nl
Sat Jan 9 21:24:21 PST 2021
On 1/10/21 2:44 AM, Daniel Baston wrote:
>> Make the CMake build adhere to CMAKE_INSTALL_LIBDIR so that multiarch
>> keeps working,
> I created a pull request for this at
> https://github.com/libgeos/geos/pull/380
> Have CMAKE_BUILD_TYPE=None define NDEBUG so that assert() is removed
>> from the code, thereby not storing the buildpath in the binaries helping
>> reproducible builds.
> If you don't specify CMAKE_BUILD_TYPE it defaults to Release, and NDEBUG
> will be defined.
But then -g is not used and there will be no debug symbols.
RelWithDebInfo is more what we need.
> Do you mean that we should define a new build type called
> "None" ?
It is used to have the buildflags set in the environment determine
optimization etc.
CMake apparently uses the absolute path for __FILE__ whereas Autotools
uses the path relative to the Makefile. Hence we get
file-references-package-build-path issues after switching a package to
use the cmake buildsystem.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
