[geos-devel] [GEOS] #1119: Buffer memory issue
GEOS geos-trac at osgeo.org
Thu Jun 3 11:14:19 PDT 2021
 Reporter:  kalenik     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.9.2
Component:  Default     |     Version:  3.9.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 Shouldn't the OOM cause a `std::bad_alloc` to be thrown, which should be
 caught by the `execute` wrapper in the GEOS C API?
Ticket URL: <https://trac.osgeo.org/geos/ticket/1119#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
