[geos-devel] [GEOS] #1119: Buffer memory issue
geos-trac at osgeo.org
Thu Jun 3 12:53:18 PDT 2021
Reporter: kalenik | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
I can't reproduce a crash here. When running the attached example under
limited memory (after plugging in ERROR and NOTICE handlers to
`initGEOS`), the ERROR handler is called with the text "std::bad_alloc".
Ticket URL: <https://trac.osgeo.org/geos/ticket/1119#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
