[geos-devel] [GEOS] #1119: Buffer memory issue
geos-trac at osgeo.org
Thu Jun 3 14:22:13 PDT 2021
Reporter: kalenik | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
I summarized and commented on these buffer memory issue in
[https://github.com/locationtech/jts/issues/735 JTS-735].
For this case, the **Buffer-By-Step** approach should work fine. This
should be fairly easy to implement.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1119#comment:11>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
